Sort By
- Tikka_Nagi_1315Historic F5 Account
ASM already covers the use of XML External Entities using signature 200018030. You can test to be sure that ASM is protecting.
- Hussein_Ghazy_3Nimbostratus
Hi Tikka
I tested the signature and it is NOT triggered! Any ideas?
Thanks and regards
Hussein
- Ashwin_VenkatEmployee
To add to what Tikka suggested, we have Signature ID 200018030 as well as Signature ID 200018018 that should provide protection against the XML External Entity injection attack vector.
