20-Mar-2020 19:10
Does VIPRION clustering (non-vCMP) work with APM? Is it supported? Can it be used to overcome the 80 Gbps maximum bulk crypto per VIPRION 4450 Blade limit for an APM remote access SSL VPN that exceeds 80Gbps of traffic?
22-Mar-2020 19:32
VIPRION works on vCMP Cluster only. You can make cluster to support APM module but license require to active. If you can create one customer then maximum bulk crypto will utilized.
22-Mar-2020 20:24
How is it possible that VIPRION works on vCMP Cluster only since https://techdocs.f5.com/en-us/bigip-14-0-0/viprion-systems-configuration-14-0-0/initial-viprion-setup.html#GUID-41AB6440-42FE-4E85-ABE8-59724CBC0E06 talks about having to decide whether to provision the vCMP feature or not and https://techdocs.f5.com/en-us/bigip-14-0-0/viprion-systems-configuration-14-0-0/viprion-system-overview.html#GUID-B931F663-9E56-4709-84EE-CC3CA6DE9005 describes vCMP as optional?
