Does F5 big ip edge client has DNS leak?
quarante
Client is using 7.1.9 and it resolves different IP from VPN with workstations connected to LAN even though they are using the same DNS.
1 REPLY 1
boneyard
MVP
MVP
i would try some packet sniffing to determine where the query goes. might be just a config issue or such.
