07-Apr-2020 12:57
Hi guys,
I am preparing to take exam 302, but I have a problem when I add the second virtual server to pool of WideIP, its disabled for "unlicensed (enabled) - not authorized".
root@(gtm-stgo)(cfg-sync In Sync)(Active)(/Common)(tmos)# show gtm pool a pool_apache_http members
Gtm::Pool::A pool_apache_http
Status
Availability : available
State : enabled
Reason : Available
Load Balancing
Preferred 26
Alternate 0
Fallback 0
Returned from DNS 0
Returned to DNS 0
Dropped 0
| Gtm::Pool Member: pool_apache_http:A vs_apache_GTD:GTM-Stgo
| Status
| Availability : unlicensed
| State : enabled
| Reason : Not Authorized
| Load Balancing
| Preferred 0
| Alternate 0
| Fallback 0
| Gtm::Pool Member: pool_apache_http:A vs_apache_http:GTM-Stgo
| Status
| State : enabled
| Reason : Available
| Load Balancing
| Preferred 26
| Alternate 0
| Fallback 0
Im working with licenses of strongbox, and i have licensed and provisioned module GTM and LTM.
sys::License
Licensed Version 12.1.5
Registration key
Licensed On 2020/04/06
License Start Date 2020/04/05
License End Date 2020/05/22
Service Check Date 2020/04/04
Platform ID Z100k
Active Modules
APM, Base, VE GBB (500 CCU) ()
Anti-Virus Checks
Base Endpoint Security Checks
Firewall Checks
Network Access
Secure Virtual Keyboard
APM, Web Application
Machine Certificate Checks
Protected Workspace
Remote Desktop
App Tunnel
BT-VE, 1G ()
Rate Shaping
SDN Services, VE
DNS and GTM (250 QPS), VE
SSL, VE
Routing Bundle, VE
ASM, VE
DNS-GTM, Base, 1Gbps
Acceleration Manager, VE
Max Compression, VE
AFM, VE
DNSSEC
GTM Licensed Objects, Unlimited
DNS Licensed Objects, Unlimited
DNS Rate Fallback, 250K
GTM Rate Fallback, 250K
GTM Rate, 250K
DNS Rate Limit, 250K QPS
DNS Rate Limit, 1000 QPS
GTM Rate, 1000
VE, Carrier Grade NAT (AFM ONLY)
PSM, VE
show sys provision
Sys::Provision
Module CPU (%) Memory (MB) Host-Memory (MB) Disk (MB)
afm 0 0 0 0
am 0 0 0 0
apm 0 0 0 0
asm 0 0 0 0
avr 0 0 0 0
fps 0 0 0 0
gtm 1 0 592 0
host 10 2582 0 112772
ilx 0 0 0 0
lc 0 0 0 0
ltm 1 0 0 0
pem 0 0 0 0
swg 0 0 0 0
tmos 88 5424 280 0
list sys provision
sys provision afm { }
sys provision am { }
sys provision apm { }
sys provision asm { }
sys provision avr { }
sys provision fps { }
sys provision gtm {
level nominal
sys provision ilx { }
sys provision lc { }
sys provision ltm {
level nominal
sys provision pem { }
sys provision swg { }
Please your help, for continue studing.
07-Apr-2020 14:29
08-Apr-2020 02:16
I open a case about this issue(gray buttion targert unlicense) 2years ago.it is a bug.no respond.
the only way is load config default,and then config one step by one.....
