Technical Forum
Direct F5 licensing & ASM updates from MGMT interface
Eslam_Sayed
Altostratus
Altostratus
Hello Sirs,
Kindly i need to enable my F5 to direct licensing traffic & ASM updates to be sourced from MGMT interface as all data interfaces are in isolated network.
Version : 13.1.3.4
Thanks in advance,
1 REPLY 1
Daniel_Wolf
Nacreous
Nacreous
Hi Eslam,
you should add a management route following the instructions in K13284: Overview of management interface routing. If your ASM is behind a firewall, you should allow access to callhome.f5.com:443 and activate.f5.com:443 (and eventually do DNS servers), so that the ASM can obtain the Live Updates.
KR
Edit: Copy and Paste from K82512024:
The BIG-IP ASM system consults the Traffic Management Microkernel (TMM) and Linux routing tables when requesting attack signature updates using the Automatic Method. The source IP address of the resulting traffic uses either a non-floating self IP address or the management IP address, depending on the matching route.
