millencol1n_619's avatar
millencol1n_619
Jan 04, 2010
delete connctions
hi,
when issuing a
b conn show all
i get
84.116.0.124:53927 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
84.116.0.124:53928 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
84.116.0.124:53929 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
84.116.0.124:53930 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
84.116.0.124:53931 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
84.116.0.124:53936 <-> 84.116.0.7:1389 <-> 10.146.116.13:1389 tcp 1/0
how can i delete those 6 connections?
i already tried b conn client 10.146.116.13:1389 delete and b conn server 10.146.116.13:1389 delete
but the sessions are still there...
thx
  • b conn client would require you use the client IP 84.116.0.124 (b conn client 84.116.0.124 delete). b conn server would be the VIP address, 84.116.0.7 (or with the VS port: b conn server 84.116.0.7:1389 delete). Or you could try b conn ss server 10.146.116.13:1389 delete (for the serverside server).
    Aaron
  • I think the ss option was added in 9.4.x. I assume you're running an earlier version.
    Aaron
  • Hmm... do you see the ss option in 'b conn help'? It works on 10.1 (and I assume on 10.0.x as well):
    b conn ss server 2.2.2.2:80
    No Conns were found.
  • no, can´t see the ss option in help...
    [root@atvieer-lb01:Active] config b conn ss server 2.2.2.2:80
    BIGpipe parsing error:
    012e0017:3: The requested item (ss server) is invalid ( | show | help) for 'conn'
    [root@atvieer-lb01:Active] config b version
    Kernel:
    Linux 2.4.21-10.0.0.5401.0smp
    Package:
    BIG-IP Version 10.0.0 5460.0
    Hotfix HF1 Edition
  • That's odd. Maybe the feature "fell out" of the first versions of 10. It's there in 9.4.x and 10.1.0 but not 10.0.x.
    Aaron
