Default SSL cipher suites
mg2Bsecure
is there a way to keep / restore default cipher suites after BIGIP major version upgrades?
1 REPLY 1
Shaun_Simmons
F5 Employee
F5 Employee
Yes, but it is not recommended to use legacy ciphers due to their vulnerabilities.
Take a look at this KB article: https://support.f5.com/csp/article/K15194
An article that will help answer your question: https://support.f5.com/csp/article/K02321234
