Michel_van_der_'s avatar
Michel_van_der_
Mar 14, 2005
Decrypting SSL SOAP traffic
I'm using Soap::Lite to do my iConrol work. I've been trying to
track donw a rather insidious bug, that proves to be hard to
find. I'd like to be able to decrypt the iControl data stream
to the BigIP using ssldump (i.e. capture my data using tcpdump,
getting the F5 server key and using that to decrypt with ssldump).
Can someone tell me where to find the SSL server key on the
F5, or, better, show exactly how it's done?
Thanks.
  • Is there a reason you aren't using SOAP::Lite's built in debugging. I'm assuming you want to decrypt the iControl message to/from the server. If you use the SOAP::Lite debugging you will get both the outbound and returning streams in clear text.
    Replace this line
    use SOAP::Lite
    with
    use SOAP::Lite + trace => qw(method debug);
    And you will get everything in clear text in your client console.
    -Joe
  • Loc_Pham_101863's avatar
    Loc_Pham_101863
    Historic F5 Account
    In 4.x, the locations of the server keys, certs, CSRs, CRLs are:
    /config/bigconfig/ssl.key
    /config/bigconfig/ssl.crt
    /config/bigconfig/ssl.csr
    /config/bigconfig/ssl.crl
    Loc
