05-Jan-2023 00:20
As part of F5 health check - one issue observed is "D2 Main memory and SWAP memory showing above 80%".
Please let me know will there be any impact due to this, also how to reduce these memory usage.
05-Jan-2023 01:07
Hi @Preet_pk ,
Maybe you configure multipule Modules as nominal in your Bigip against SWAP allocated memory ,
I will send some Linkes explain F5 memory high utilization in general and SWAP memory as well :
> https://support.f5.com/csp/article/K55227819 >>> For Swap memory
> https://community.f5.com/t5/technical-forum/big-ip-ltm-other-system-memory-and-swap-memory-usage/td-...
this is an old enquiry for SWAP memory as well
> https://f5partnerdashboard.force.com/DevCentral/s/question/0D51T00008zP8jySAC/swap-memory-increase-u...
you will find in this Link another 3 links shows F5 memory overview for more comprehensive and SWAP memory issues
Hope you find it useful.
06-Jan-2023 05:46 - edited 06-Jan-2023 06:22
If you using the API on F5 this can also happen from time to time and if you have more traffic than the system can handle it can enter memory leakage state from what I have seen.
