tolinrome_13817's avatar
tolinrome_13817
Apr 17, 2014
Customize logon page
Hello,
I intended to customize the logon page by uploading an image. I went to Access Policy>Customization>Advanced and under Logon Page" in the folder hierarchy there is a General icon and I tried to replace that vaule (front image) with the one I wanted. It seems as if it didnt take. When I then tried the website I got a "404 error no page found". I couldnt figure out what to do so I decided to go to the second node and force the config "Overwrite configuration" to the first node where I was making the changes. When I synched it synched and all the indicators are green circles but on the top left part of the page it says "Not All Devices Synced" and the web page still says ""404 error no page found". Any ideas?
  • Three important steps:
    1. Upload the image via the image browser. Assuming you already did this.
    2. For the Front Image, click on the value, click on the icon to the right of the value, click the Replace button, select the image you uploaded in step 1, and then while the URI path is highlighted in the value box, hit the Enter key. That should change the value to look something like this:
      /public/images/customization/Common/custom-logon_act_logon_page_ag/front_image_en.JPG
    3. Click the Save button in the Customization window and then apply the access policy.
