Technical Forum
Custom Alert Banner
Custom bash script at startup doesn't work (BIG-IP VM 17.1.1)
aquerci
I need to run a custom script at the startup of my BIG-IP VM (version: 17.1.1 Build 0.0.6 Final). In order to reach my goal, I followed this articole by F5 but unfortunately it didn't work:
https://my.f5.com/manage/s/article/K11948
the startup_script_sol11948.sh file didn't exist so I creted it by my self in /config/, edited, saved and made it executable. if I run it via CLI it works, but the system doesn't run it at the startup (I tried to reboot many times). where am I going wrong?
1 REPLY 1
Lucas_Thompson
F5 Employee
F5 Employee
The way that article is organized may lead to some confusion, because there are two initial procedures at the top that gives instruction to create a script and set it executable, but in two slightly different ways depending on version. Then below the "old version" procedure there is another one for "Enable the BIG-IP or BIG-IQ system to run the script". If you missed the last part, it would lead to the behavior you described.
