OttimoMassimo_1
May 20, 2013Creatign SSL CSRs - V11.x
Any idea how I can create an SSL CSR (preferably from the GUI) in v11.x? is this the only option http://support.f5.com/kb/en-us/solutions/public/11000/400/sol11438.html ?
Thanks!
- Kevin_Stewart
Employee
Go to System - File Management - SSL Certificate List tab, and click the Create button. Select "Certificate Authority" from the drop down, fill in all of the required values and submit. The next page will allow you to download the resulting CSR. - OttimoMassimo_1
Thanks very much Kevin. That did it.
