21-Jun-2023 04:56
Hello guys!
We need to implement a specific combination of monitors for our backend servers: One https check and one SNMPv3 monitor.
Sad thing is that F5 predefined SNMP monitors do not support SNMPv3 so we have been conidering the option to use an external monitor in the form of bash script, performing the SNMPv3 query and based on the response we shall mark the backend as UP or DOWN...
Unfortunately I was not able to find much info on this topic.. Has anyone of you ever had the need to use SNMPv3 for monitoring pool members?
Cheers!
Dunkov
Solved! Go to Solution.
21-Jun-2023 07:05
Do this in two stages:
https://www.linickx.com/snmpwalk-v3-and-snmpget-v3-examples
21-Jun-2023 07:05
22-Jun-2023 15:38
You can work that excellent info from @PeteWhite into the external monitor that is already templatized for you in the codeshare: https://community.f5.com/t5/codeshare/snmp-check-external-monitor/ta-p/285358
HTH...Jason
22-Jun-2023 22:15
Thank you guys! The solutions suggested by @PeteWhite really helped us out!
Cheers!
