Technical Forum
Create a fqdn node in CLI
steven_normole
Altostratus
Altostratus
I am trying to create FQDN nodes through the CLI.  When i type in the command the F5 returns an error that the FQDN is invalid and the node exist.
I checked the GUI and the conf file and this node does not exist.  Any ideas
create ltm node name www.msn.com fqdn {name www.msn.com autopopulate enabled interval 0}
01070734:3: Configuration error: Invalid FQDN : the node already exists for (www.msn.com)
1 ACCEPTED SOLUTION
can you do one more thing here. In tmsh mode just type ltm and go inside of ltm module
then run below command lets see
(tmos)ltm# create node name www.msn.com fqdn {name www.msn.com address-family ipv4 autopopulate enabled interval 0}
if still issue open ticket with f5 support team
4 REPLIES 4
Samir
MVP
MVP
I belive you are missing "address-family [ipv4 | ipv6]"  parameter
create ltm node name www.msn.com fqdn {name www.msn.com address-family ipv4 autopopulate enabled interval 0}
 Try this.
I think that is a default, but just to make sure i added the address-family ipv4 and I am setting getting the same error returned.
I went through the conf file and there is no reference to what I am trying to do by using the CLI.  In the GUI i can create the FQDN with no errors.
clicked wrong button.  still have the same issue.  i appreciate the assistance, but looks like will have to open a ticket with f5
