Create a VPC VoltMesh AWS site (two interfaces node)
Problem this snippet solves:
How to create a VoltMesh node inside an existing VPC. The VoltMesh node will be a two interfaces node and so could be used as both an ingress or egress gateway for the VPC.
How to use this snippet:
Pre-Requirements:
- Get and create the following from the AWS console:
- Get the ID of the VPC in which you want to deploy the VoltMesh node
- Get the ID of the "workload subnet" where are sitting the ressources you want to expose with the VoltMesh node in the VPC
- Create and get the ID of the following:
- One subnet (/28 for instance) that will be used as "outside" subnet for the VoltMesh node ie handling the Internet connectivity
- One subnet (/28 for instance) that will be used as "inside" subnet for the VoltMesh node
For more information regarding our AWS concepts, please refer to: https://www.volterra.io/docs/how-to/site-management/create-aws-site
- Have entered your AWS account credentials within the Volterra console. Please refer to: https://www.volterra.io/docs/how-to/site-management/cloud-credentials
- Have a Volterra API Certificate. Please see this page for the API Certificate generation: https://volterra.io/docs/how-to/user-mgmt/credentials
- Extract the certificate and the key from the .p12:
openssl pkcs12 -info -in certificate.p12 -out private_key.key -nodes -nocerts
openssl pkcs12 -info -in certificate.p12 -out certificate.cert -nokeys
- Create a variables.tf Terraform variables file:
variable "api_cert" {
type = string
default = "/<full path to>/certificate.cert"
variable "api_key" {
type = string
default = "/<full path to>/private_key.key"
variable "api_url" {
type = string
default = "https://<tenant_name>.console.ves.volterra.io/api"
- Create a main.tf Terraform file:
terraform {
required_version = ">= 0.12.9, != 0.13.0"
required_providers {
volterra = {
source = "volterraedge/volterra"
version = ">=0.0.6"
provider "volterra" {
api_cert = var.api_cert
api_key = var.api_key
url = var.api_url
In the directory where your terraform files are, run:
terraform init
Then:
terraform apply
Code :
resource "volterra_aws_vpc_site" "aws-vpc-example" {
name = "aws-vpc-example"
namespace = "system"
aws_region = ""
assisted = false
instance_type = "t3.xlarge"
//AWS credentials entered in the Volterra Console
aws_cred {
name = ""
tenant = ""
vpc {
vpc_id = ""
ingress_egress_gw {
aws_certified_hw = "aws-byol-multi-nic-voltmesh"
no_forward_proxy = true
no_global_network = true
no_inside_static_routes = true
no_outside_static_routes = true
no_network_policy = true
//Availability zones and subnet options for the Volterra Node
az_nodes {
//AWS AZ
aws_az_name = ""
//Site local outside subnet
outside_subnet {
existing_subnet_id = ""
//Site local inside subnet
inside_subnet {
//Workload subnet
workload_subnet {
//Mandatory
logs_streaming_disabled = true
//Mandatory
no_worker_nodes = true
} Tested this on version:
No Version FoundPublished Oct 25, 2021
Version 1.0Philippe_Veys
Employee
Joined October 13, 2021
