Livius's avatar
Livius
Icon for Cirrus rankCirrus
Mar 07, 2023
CPU monitoring for F5
Hi all,
Our Viprions are experiencing CPU spikes of > 80% on a hourly basis.
We already have the # tmsh modify /sys db cpu.logthreshold value 80 set, but that only triggers an alert if we have >5min threshold crossed.
Is there any way to get more granular, to monitor and alert when for 5s intervals?
Thanks in advance!
  • Gajji's avatar
    Gajji
    Yes I guess, it is possible to monitor and alert on CPU spikes for smaller intervals using the BIG-IP system's event system and scripting capabilities.
  • Are you looking for diagnostics or monitoring?  5s is a very short interval for monitoring.   What needs to happen is shorter polling interval, but that 5m interval may be a limitation of the service.  It may take a 3rd party monitoring tool to give you greater frequency.
