Wendell's avatar
Wendell
Sep 24, 2021
Couple of questions. irule pool validation and call?
I have a couple of questions. The first is can I make a simple pool call to mystaging_stageb
if { [HTTP::cookie exists "clicklink"] } {
      switch [HTTP::cookie value "language"] {
            es {
                HTTP::header replace "Host" "hostdevelopmentservername.com"
                pool mystaging_stageb
            default {
              if { [active_members CHECKMY_DEV01_WITH_PROXY] eq "0" } {
                switch [string tolower [HTTP::uri]] {
                  "/" { HTTP::respond 200 content [ifile get Maintenance.html] }
                  "/alert.png" { HTTP::respond 200 content [ifile get Alert.png] }
                  "/logo.png" { HTTP::respond 200 content [ifile get logo.png] }
                pool CHECKMY_DEV01_WITH_PROXY
         if { [HTTP::cookie exists "language"] } {
              es {
                HTTP::header replace "Host" "hostdevelopmentservername.com""
              default {
                if { [active_members CHECKMY_DEV01_WITH_PROXY ] eq "0" } {
Secondly, can I update my pool mystaging_stageb to not do an activate member heatlhcheck how do I turn this off or do I need to create a new pool without the healthcheck?
Third: how do i move from my snat pools to automap can this be updated or do i need to create new snat pools?
