Technical Forum
Could not login with a VS on F5
FAJUMO
Cirrus
Cirrus
We have an application on port 8181 and was passed through reverse proxy.
Once we access the Application with its real IP, we can login.
but when we login in with the reverse proxy IP/FQDN we get this error : Unable to submit form.
Please i need your expertise on the issue
9 REPLIES 9
Hi Fajumo,
Could you share the configuration of the virtual server handling the reverse proxy requests?
the command is: tmsh list ltm virtual <name of the virtual server>
and any irules connected to this virtual server.
Cheers,
Kees
ltm virtual reverseproxy.etisalat.com.ng {
   description "Central VS to handle the untrusted published applications"
   destination 41.190.21.150:https
   ip-protocol tcp
   mask 255.255.255.255
   profiles {
       Etisalat_tcp-lan-optimized {
           context serverside
       Etisalat_tcp-wan-optimized {
           context clientside
       etisalat_http_profile { }
       etisalat_stream_profile { }
       serverssl {
           context serverside
       wildcard1.9mobileng.com {
           context clientside
   rules {
       Reverse_proxy_irule
   source 0.0.0.0/0
   source-address-translation {
       type automap
   translate-address enabled
   translate-port enabled
   vlans {
       ExtVLAN
   vlans-enabled
   vs-index 143
Irule is too long to add here. please send me email to send it to
Questions.
The webserver is listening on port 8181, it this HTTPS??
Do you need the stream profile for the Reverse_proxy_irule?
Please post the irule here (you can use the Code Snippet button to make it more readable.
Cheers,
Kees
   STREAM::disable
   SSL::disable serverside
interconnectuat.9mobile.com.ng {
               log local0. "[HTTP::host] detected. Going to send to Pool interconnectuat.9mobile.com.ng"
               SSL::enable serverside
               pool interconnectuat.9mobile.com.ng
Ok, during the login, are there any error's in /var/log/ltm related to this irule?
I tried to get a capure but did not see any hit
1. Create a new decryption irule:
when CLIENTSSL_HANDSHAKE {
log local0. "Client IP: [IP::client_addr] TCP source port: [TCP::remote_port] client"
log local0. "RSA Session-ID:[SSL::sessionid] Master-Key:[SSL::sessionsecret]"
log local0.debug "CLIENT_RANDOM [SSL::clientrandom] [SSL::sessionsecret]"
when SERVERSSL_HANDSHAKE {
log local0. "Client IP: [IP::client_addr] TCP local port: [TCP::local_port] server"
2. Add this irule to your VS which is handling the affected traffic.
3. Run tcpdump:
tcpdump -envi 0.0:nnnp -s0 -w /var/tmp/"$HOSTNAME"_"$(date +%d-%m-%y)".pcap host <Your-client-IP>
4. Generate traffic and catch the problem.
5. Stop tcpdump
6. Disable decryption irule
7. Run below commands to create the files with session keys:
sed -e 's/^.*\(RSA Session-ID\)/\1/;tx;d;:x' /var/log/ltm > /shared/tmp/sessionsecrets.pms
grep -h -o 'CLIENT_RANDOM.*' /var/log/ltm > /shared/tmp/sessionsecrets_random.pms
FAJUMO
Cirrus
Cirrus
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at https://10.161.33.126:8181/wbs_RESTAPI/authenticateUser. (Reason: CORS request did not succeed). Status code: (null).
