Technical Forum
CORS Reponse Headers-403 Forbidden
Christy_Love
I am working with our DBA/Applications teams to assist with a CORS related issue.
In an attempt to resolve the issues I have written several iRules to insert a HTTP response header, none of which work.
I have focused on one particular iRule, taken form a related DevCentral article posted in 2015.
https://devcentral.f5.com/s/question/0D51T00006i7azP/adding-cors-response-headers
Has anyone had any success with this and can you share the iRule written?
Below is the latest iRule I have written and applied to the F5 front-end:
    set debug 0
   set Origin ""
if {[HTTP::header exists "X-tls-debug"]} {
       set debug 1
if {$debug} {
       set prefix "\[[TCP::client_port].[expr {int (rand() * 100000)}]\] "
  if {[HTTP::header exists Origin]} {
       if {$debug} {log local0. "${prefix} Origin:[HTTP::header Origin]"}
       switch -glob -- [HTTP::header Origin] {
           "*company1.com" -
           "*company2.com" -
              [HTTP::method] {
                   "OPTIONS" {
                       if {$debug} {log local0. "${prefix} Responding to Preflight request"}
                       HTTP::respond 403 forbidden Allow "GET,HEAD,POST,OPTIONS" \
                                                   Access-Control-Allow-Origin "[HTTP::header Origin]" \
                                                   Access-Control-Allow-Methods "GET,POST" \
                                                   Access-Control-Max-Age "86400"
                       return
                   "GET" -
                   "POST" {
set Origin [HTTP::header Origin]
               if {[HTTP::method] eq "OPTIONS"} {
                   if {$debug} {log local0. "${prefix} Responding to OPTIONS method"}
                   HTTP::respond 403 forbidden Allow "GET,POST,HEAD,OPTIONS"
                   return
when HTTP_RESPONSE {
   if {$Origin ne ""} {
HTTP::header insert "Access-Control-Allow-Origin" $Origin
      HTTP::header insert "Access-Control-Allow-Methods" "GET,POST"
      HTTP::header insert "Access-Control-Max-Age" "86400"
      HTTP::header insert "Allow" "GET,HEAD,POST,OPTIONS"
   HTTP::header insert "Vary" "Origin"
0 REPLIES 0
