Jim_Raleigh's avatar
Jim_Raleigh
Feb 01, 2018
Converting iRule from v9 to v12
In the process of migrating from v9.4.7 to v12.1.1 and am having issues with iRules... In the following I am pulling string Data Groups for B2B_Blocked_URLS and B2B_URLS... Could you assist on how I would do this on the new version?
when RULE_INIT {
    set ::DEFAULT_URI "/b2b/init.do"
    if { [matchclass [HTTP::uri] contains $::B2B_Blocked_URLS] } {
        HTTP::redirect "$::DEFAULT_URI"
    if { [matchclass [HTTP::uri] contains $::B2B_URLS] } {
        log local0.crit [HTTP::uri] HTTP::redirect "$::DEFAULT_URI"
  • Hi Jim,
    You can try the following, please be advised you can now achieve the same results using a Traffic Policy (configured in the GUI). Code that is no longer supported are variables declared in the global namespace ($::var) these will demote your CMP so the iRule will only run on one CPU. Also matchclass has been deprecated
    when RULE_INIT {
        set static::DEFAULT_URI "/b2b/init.do"
        if {[class match [HTTP::uri] contains B2B_Blocked_URLS] } {
            HTTP::redirect $static::DEFAULT_URI
        } elseif { not ([class match [HTTP::uri] contains B2B_URLS]) } {
