Manikanta's avatar
Manikanta
Aug 05, 2019
connectivity test
I would like to check the access to the backend servers on a particular port from SNAT IP as source.
Do we have any telnet option available with F5?
  • JG's avatar
    JG
    You can use "nc" with the flag "-s", or "curl" with the flag "--interface".
  • i do some test with nc and the flag -s , it's doesn't work 😑 (nc: bind failed: Cannot assign requested address)
    the SNAT IP is unknowned to linux system.
    • JG's avatar
      JG
      You can specify the IP address of the interface representing the egress VLAN of the SNAT addresses, for the purpose of checking connectivity to the back-end application servers.
