Technical Forum
connection stickiness
suthomas1
Good day all,
After traffic passes through a virtual service, what is the best way to check upon stickiness/persistence for those connections.
or for any checks after these stickiness configuration has been amended, is there a way to verify the connections are keeping those persistence.
Thanks in advance.
1 ACCEPTED SOLUTION
ant77
Cirrus
Cirrus
If this is what you are referring to...from TMSH
show ltm persistence persist-records <virtual server name you want to check persistence>
-And for UIE persistence-
show ltm persistence persist-records mode universal <virtual server name you want to check persistence>
1 REPLY 1
ant77
Cirrus
Cirrus
