18-Sep-2023 23:57
Hello,
I got an api backend service behind an F5, the problem is if Virtual Server is Standard then client gets "Connection reset by peer", the problem is disapeared if i switch to Performance (HTTP).
However, Performance HTTP would not allow to config application security policy, so is there any solution for Standard type.
Thank you
19-Sep-2023 02:48
Have you got health monitors or http profiles turned on?
19-Sep-2023 04:56
Hi @TD-Bernie,
- Enable rest cause ( Log & Packet ) >>> https://my.f5.com/manage/s/article/K13223
- Check /var/log/ltm >> while applying http profile.
- Take a Pcap again >> and check all of reset packets.
Note ( Do that while applying http profile )
- Also Create custom http profile >>> try to modify Maximum header size & header count.
Refer to those articles :
https://my.f5.com/manage/s/article/K8482
https://my.f5.com/manage/s/article/K22518624
>>> you can share the Pcap if you want to have a look.
20-Sep-2023 21:31
Hello Mohamed,
I am not sure the root cause of this problem, but it seems to be network issue cause i checked at that night, the connection was okay again, it kept unstable until i tried to change ip address of virtual server (i could make sure there is no ip conflict).
Thank you.
25-Sep-2023 21:28
@TD-Bernie - if you got an answer that led to a solution it would be helpful to the future-community-selves to click Accept As Solution.
Thanks for joining and being part of our community.
