kona2-9_51980's avatar
kona2-9_51980
Jan 23, 2013
Client Authenication using LDAP
I am looking for a config paper or tech guide on how to setup Client Auth using LDAP in APM then pinning that To my LTM in a VE 11.2.x I have been totaly unsuccessful in finding this with my search strings. I am looking for the F5 to terminate the connection from the host to VIP (http/https) query the AD box associated with the domain requested. I have a F5 VE 11.2.x running LTM and APM. Anyone that can point me in the correct direction would be appreciated.
  • I'm not sure I understand exactly what you are trying to achieve, does the below cover it?
    1.) Have one logon page that is accessible by either http or https from the internet
    2.) Allow users from 2 different domains to use this logon page (ie specify their domain somehow)
    3.) Get ATM to authenticate the user to one of two AD's based on the domain they selected from the logon page
    4.) Send the user to 1 of 4 different possible destinations, abc.com on http or https; def.com on http or https; dependent on whether they hit the logon page with SSL or not
