cli preference display-threshold 0 for all users
fubarSUSHI
Altocumulus
Altocumulus
Im trying to find a way to modify tmsh cli preference display-threshold 0 for all users. If I run it on my user account or even root... it only modifies it for the given user account. Is there a way to make this a global command for all users?
3 REPLIES 3
boneyard
MVP
MVP
never done anything with it, but looking at this you might get somewhere with changing the /config/bigip_user.conf file :
https://devcentral.f5.com/s/question/0D51T00006i7hIMSAY/is-cli-preference-setting-for-a-userspecific-setting
do test this well before trying in production.
Well provided the users are not TACACS based, because I think bigip_users.conf would come into picture only for LDAP users.
Also if the users are from LDAP, then he would manually require to put entry for every users as cli preference and load the files later, which would need to go under planned maintenance window.
not sure about the TACACS part and certainly not the perfect solution.
but im not aware of anything better, perhaps someone else.
