Citrix iApp Citrix-vdi-v2.4.3 issue
Hello dears i SW version is 12.1.2 and i have this strange iApp issue while am configuring iApp it doesnt see the AD that i have already created so i configured iApp to create a new AD but when i press finish in the end it give me this error :-
while executing "tmsh::create [string range $args 7 end] " ("create" arm line 1) invoked from within "switch -exact -- [string range $args 0 5] { create { tmsh::create [string range $args 7 end] } modify { tmsh::modify [string r..." (procedure "iapp_conf" line 14) invoked from within "iapp_conf create apm aaa active-directory ${app}_aaa { admin-encrypted-password [expr { $allow_anonymous ? "none" : "[iapp_make_safe_password "$:..." invoked from within "subst $apm_aaa($new_aaa)" invoked from within "subst $pre_proc_map" invoked from within "if { $is_lb_scenario } { set apm_profiles "" set port $::webui_virtual__https_port subst $vs(web) if { $create_redir_vs } { su..." line:1654)
Note that it is the official F5 iApp for citrix deployment and i have tested in 13.0.0 its working perfectly ... support told me that he tested in 12.1.2 and its working and he told me to remove HSL cuz it might be conflicting iApp but also i didnt work ... any ideas about what may causing the issue????
