Technical Forum
Custom Alert Banner
Citrix Dekstop inactivity timeout
cd
Cirrus
Cirrus
Hello,
I have a VS with full webtop/Citrix Desktop application and F5 replacing the storefront, it's work fine but the inactivity timeout doesn't work
I have it on 3600 seconds on Access profile and it's working fine with portal access
How can I logout a client who use a VM after a period of inactivity, Is it possible like the User inactivity in Netscaler Gateway ?
1 ACCEPTED SOLUTION
cd
Cirrus
Cirrus
Thanks for your response,
Yes I want to cut off the VM after some hours of inactivity..
There are no irule for that in the iApps but I guess since there are all time traffic between client and the F5 to display the VM, it can't detect there are no activity or something..
I will try to set it on the citrix environment instead
2 REPLIES 2
Heino
Cirrus
Cirrus
I'm not certain what you want to do (I'm not that familiar with Citrix products)
Do you want to cut the connection to the client?
Do you want to tell the server that the client has left the session?
Anyway, this sounds like something that might have been configured in an iApp, so it is possible that a timer has been set in an irule, or that the tcp profiles have been configured with a keep alive, that ensures the connection won't die.
cd
Cirrus
Cirrus
