Technical Forum
Choose next IP for SNAT Pool - Ansible
johnramzf5
Altocumulus
Altocumulus
when working with this module: f5networks.f5_modules.bigip_snat_pool , I have this requirement:
Create a SNAT Pool with one individual IP from an arbitrary range (192.168.11.1 - 192.168.11.250) for every new Virtual Server. So for "Virtual Server 1" the SNAT pool IP is "192.168.11.1", for "Virtual Server 2" the SNAT pool IP is "192.168.11.2", so on and so forth.
How can I add that logic when working with this module?
Thank you
john
2 REPLIES 2
mihaic
MVP
MVP
have you tried to use  a list of IP's and :
loop or with_itmes : https://docs.ansible.com/ansible/latest/playbook_guide/playbooks_loops.html
Thank you for your reply. I will research how to work with loops in Ansible to test those steps out
