Joel_Breton
Jun 01, 2017Change default Route Domain for a Partition - Python F5-SDK
I am trying to change the default route domain for a partition using the F5-SDK.
Here's my code to create the partition and route domain
from f5.bigip import ManagementRoot
bigip = ManagementRoot('ipaddress', 'user', 'password')
newpart = bigip.tm.sys.folders.folder.create(name='mypartition',subPath='/')
newrd = bigip.tm.net.route_domains_route_domain.create(name='myrd', id='1', partition='mypartition')
After running the script my partition is created and my route domain is created now I need to change the default route domain for my new partition. By default the partition gets assigned the default route domain 0.
Here's what I've tried
newpart.update(default_rd_id='1')
If I browse the API https:/localhost/mgmt/tm/sys/folder I can't find the value to modify
kind: "tm:sys:folder:folderstate",
subPath: "/",
fullPath: "/mypartition",
generation: 38,
selfLink: "https://localhost/mgmt/tm/sys/folder/~mypartition?ver=12.1.2",
deviceGroup: "none",
hidden: "false",
inheritedDevicegroup: "true",
inheritedTrafficGroup: "true",
noRefCheck: "false",
trafficGroup: "/Common/traffic-group-1",
trafficGroupReference: {
link: "https://localhost/mgmt/tm/cm/traffic-group/~Common~traffic-group-1?ver=12.1.2"
