Changes in bigip.conf not reflecting in GUI
I need to create similar pools from one of the partitions with different pool name. So I modified the bigip.conf file and saved the file in tmsh. But it is not reflecting in the GUI. Am I missing something ?
- Vijay_E
Cirrus
It isn't recommended to edit the configuration files directly. If you are relatively new to F5, avoid direct editing of the files.
If you still want to proceed editing the configuration files directly, you would need to execute the following after editing the file:
tmsh load sys config - JG
Cumulonimbus
Log out of the Configuration Utility and re-login. You might need to empty the browser cache.
- Viv_Richards
I am facing similar issue
I have performed below command but there is no use
tmsh save sys config
- Sachin-Garg
Altostratus
Its best to use the following command to add the new pool with new details by copying the old pool details:
load sys config from-terminal merge
Copy and paste the configuration through F5 cli terminal
user@(xxx)(cfg-sync In Sync)(/S1-green-P:Active)(/partition)(tmos)# load sys config from-terminal merge
Enter pool configuration( which you have already prepared for new pool or use right click for paste option to paste the pool config)
Press CTRL-D to submit or CTRL-C to cancel.
- Viv_Richards
Hi Dear ,
Issue resolved after issuing below commands
tmsh load sys config partition all
