veato's avatar
veato
Feb 19, 2018
Change Webtop Remote Desktop Icon
I have an access policy for VMware VDI and I can't seem to change the icons for my webtop/remote desktop links.
The default icon is "terminal_service.png" located in /var/sam/www/webtop/public/images/full_wt
I have changed this to an icon with the same dimensions (32px) in Access Policy>Customization>Basic>Remote Desktop and General>Branding>Remote Desktops but still the old icon is dispayed.
Any ideas?
  • Did you change it for any languages! This customization can be different for each language!
    • AMiles_377865's avatar
      AMiles_377865
      In the past, I have also made changes to some webtops that were not reflected in the GUI for a good 15-20 minutes. But I've also made changes in different environments that were reflected instantly. I have tried clearing browser caches, clearing ram_cache, and switching browsers, none of which resolved the issue.
      Do know of any other solution? Is apm caching the webtop information somewhere?
    • Dave_Li_331092's avatar
      Dave_Li_331092
      I did clear the cache but it didn't work. Also, browsing to https:///public/images/customization/Common//image_en.png dose display the updated image.
      The icon I'm updating is for a remote desktop resource and compare to other resources such as portal/network access, it is kind of "dynamic" (valid remote desktop resources/icons are enumeration by a mid-layer server which authorizes the user). Don't know if that makes things a bit different.
  • Hi,
    I have the same issue now.
    I also clear the cache and it didn't work.
    Did you found solution for this?
