Technical Forum
Capturing an HTTP Body and adding it to SAML attribute
AAA001
We have a requirement to capture a portion of an incoming HTTP Body and add it to an outgoing SAML response. I also need to convert this to XML after capturing. Once that is completed it will need to be added to a session variable and sent out in a SAML response.
Is this the best way to do it? This will involve using a combination of iRules and APM policies.
Any guidance, examples and documentation on this will be appreaciated.
Thank you
1 REPLY 1
Paulius
MVP
MVP
@AAA001 I believe this should get you on your way without knowing specifics on what is being moved from the HTTP body to the SAML response.
https://my.f5.com/manage/s/article/K07535385
https://clouddocs.f5.com/api/irules/ACCESS__saml.html
