17-Sep-2015 11:58
I need an irule to capture the characters between slashes in a uri. For example, in the uri www.example.com/test1/test2/test3/ i want to set a variable value to what ever is between the second and third slashes which in this case would be test2.
17-Sep-2015 13:39
Hi, try this
cheers
set a [getfield [HTTP::path] "/" 3]
log local0. "value = $a"
$curl http://10.12.12.145/test1/test2/test3/
config info tmm1[17994]: Rule /Common/getfield : value = test2
