08-Feb-2021 13:09
09-Feb-2021 07:44
The Edge Client will attempt to reconnect, prompting the user to enter credentials. Once you click on "Connect" it will do that until you click "Disconnect". What I want to achieve is to go to "Disconnect" without user intervention, right after the session reaches the timeout.
16-Feb-2021 12:25
Angorya I am having the same issue on my F5 as well. After my maximum session timeout value is hit the client will then attempt to prompt the user to login again. This happens all night long as the inactivity timeout keeps getting hit. This only started happening after upgrading to v15 firmware. I have a ticket open with F5 Support but haven't had any luck with them either.
27-Feb-2021 04:57
did you hear anything form F5 support in the mean time?
