Technical Forum
Cache control
Kia
is there any way to disable cache control on F5 LTM? this was recently flagged during security scan on F5 VIP.
1 REPLY 1
AlexBCT
MVP
MVP
Hi Kia,
What kind of cache control are you referring to? Is it cache headers? Or the LTM caching responses or cache from management pages or ssl session caching?
Basically you can tweak anything on these boxes, so probably won't be a problem, but would be good to have some more background knowledge on the exact issue that was found.
