Technical Forum
Bypass SSL offload for selected source IPs
Sajeev
Hallo, I have a scenario to bypass the SSL offloading for selected source IPs, and just loadbalance with the pool members.
The remaining sources should offload in the F5 and then proceed.
is there a way to implement this? (irule or any other ..)
1 REPLY 1
You can do this with a local traffic policy. Based on source IP select a virtual server with client SSL or without.
Cheers,
Kees
