islam_nadim's avatar
Oct 14, 2020
Block OWA Users Based on Domain
Hello All,
Is there a way to block the users accessing the OWA through the F5 using their domain?
For example, I have 2 domains; domain1.com and domain2.com .. I want only users from domain1.com to be able to use OWA, but users from domain2.com to be blocked.
Is this possible on ASM/LTM level?
  • Hi islam.nadim,
    ASM:
    Security  ››  Application Security ›› Headers ›› Host Names
    add host names
    Security  ››  Application Security ››  Policy Building ›› Learning and Blocking Settings
    ›› Headers
    ›› Illegal host name
    Enable alarm and block settings
    Save Policy
    Apply Policy
    LTM:
    iRule:
    	if { [HTTP::host] ne "domain1.com" } {
    		drop
    Policy:
    • islam_nadim's avatar
      islam_nadim
      Icon for Cirrus rankCirrus
      Hello  ,
      Thank you for the reply, maybe I haven't cleared exactly what I'm looking to achieve. It is not related to DNS or FQDNs. It is related to logging in to the OWA. So, if a user types <Username>@domain1.com, he can access .. But if he types <Username>@domain2.com, ASM should block such traffic ..
      I mean, I want only <Username>@domain1.com to be working, but any other domain to be dropped showing ASM block page.
      Hope this clears what I'm looking to achieve.
      • Ivan_Chernenkii's avatar
        Ivan_Chernenkii
        Hello,
        Do you have any login page in your ASM configuration?
        If you deal with logging, then better to configure appropriate login page.
        Thanks, Ivan
