alan_2982's avatar
alan_2982
Jan 29, 2009
bigpip virtual show
I just upgraded from v4 to v9 and I might be seeing an artifact of that. It's also pretty likely that I am forgetting how to produce the output I want.
I am documenting virtuals, pools, and rules for an auditor. I gave them a report last time they asked that looked like this:
 VIRTUAL 192.168.100.5       UNIT 1
    +---+--> SERVICE   80              ENABLED
        +---+--> RULE www
            +---+--> POOL blackhole
            |   +--> MEMBER 192.168.0.58:80         UP
            +---+--> POOL mf-virtual
            |   +--> MEMBER 192.168.0.89:80         UP
            |   +--> MEMBER 192.168.0.90:80         UP
now, the closest thing I can find is produced by bigpipe virtual show like this:
 |        ARP: enabled
 |        (cur, max, limit, tot) = (0, 1, 0, 5)
 |        (pkts,bits) in = (15, 25768), out = (10, 5120)
 +-> SERVER www.foo.com-80   SERVICE http
     |        PVA acceleration none
     |        requests (total) = 0
     +-> RULE www
         +-> HTTP_REQUEST   5 total  5 fail  0 abort
Any help in remembering how to produce the earlier output is much appreciated.
Thanks,
Alan
  • Hmm, grep is acting weird when pipe to from bigpipe...anyway, this is more inline with want you want. I'm sure it can be condensed.
    b virtual show all | grep -v \( | grep -v \| | grep -v total
  • hoolio's avatar
    hoolio
    You can use egrep to search for multiple strings OR'd together to remove lines containing the following characters/string: ( | total
    b virtual show all | egrep -v '(\(|\||total)'
    Or you could look for lines containing VIPs, rules and pools:
    b virtual show all | egrep '(VIRTUAL|RULE|POOL)'
    Aaron
  • yeah, that's what I tried to do with grep, but got errors. Forgot about egrep...how quickly the sysadm skills fade. Thanks!
