James_Yang_9981's avatar
James_Yang_9981
May 14, 2009
BIGIP 10.0 support issue
I just successfully install the mpack. but when I discover a V10 device, it's failed with following log:
Execute device discovery:Failure
Failure Message: F5Networks.ManagementPack.Discovery.DiscoveryException: Big 3d update from version 10.0.0.5401.0.0 to version 10.0.0.5999.0.0 was not authorized
does this means the 10.0 is still not supported?
  • Stephen_Fisher_'s avatar
    Stephen_Fisher_
    Historic F5 Account
    Hello,
    Thanks for your question. The message you are seeing relates to impact on Global Traffic manager, and the update of Big3d.
    I provided some more information in this Forum post:
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=59&postid=34273&view=topic
    You can authorize the update by checking the box in the discovery wizard or specifying UpdateBig3d from your script.
    Thanks,
    Stephen
