09-Aug-2022 05:27
Going through the datasheet documents for SSL orchestrator and Platform I see different throughput values for SSL orchestrator Throughput vs Platform L7-L7 traffic processing throughput.
What is the difference between these throughput? Using SSL Orchestrator does the Platform throughput decrease and limited to what SSL orchestrator Maximum Throughput is ?
https://www.f5.com/pdf/products/ssl-orchestrator-datasheet.pdf
https://www.f5.com/pdf/products/big-ip-platforms-datasheet.pdf
Solved! Go to Solution.
22-Aug-2022 06:10
The platform data sheet is giving you raw throughput for the device. And for SSL (TLS handshake and encryption) these numbers reflect a single decrypt operation.
SSL Orchestrator throughput differs then in the following ways:
24-Aug-2022 21:30
It is definitely worthwhile to start with SSLO 9.x (9.3 on BIG-IP 16.1.3 is the latest 9.x release as of Aug 2022).
15-Aug-2022 11:56
hey @DevBabu - I'll reach out to some SSLO experts and see if they can answer this for you.
16-Aug-2022 09:05
Thanks.
22-Aug-2022 06:10
23-Aug-2022 14:29
@Kevin_Stewart Thanks.
Reading article Update or upgrade the F5 SSL Orchestrator | BIG-IP update and upgrade guide, sounds like SSL Orchestrator contains significant stability improvements in 16.1.x - 9.x. Since, we haven't provisioned SSL Orchestrator in v15.x devices, would it be wise to upgrade device to 16.1.x and provision/configure SSLO. I think this will help in us doing the workaround mentioned in the article.
24-Aug-2022 21:30
30-Aug-2022 14:49
@DevBabu - If your post was solved it would be helpful to the community if you selected *Accept As Solution* on the relevant reply (or replies). This helps future readers & searchers find answers more quickly and confirms the efforts of those who helped. (Thanks @Kevin_Stewart)
Thank you for being part of our community.
Lief
