Ronenb's avatar
Ronenb
Icon for Cirrus rankCirrus
Dec 13, 2022
BIG-IP i5600 and throughput limits
Hello
Please advise on the i5600  throughput limits base on AWAF license .
Ronen
  • Hi Ronenb ,
    There is no relation between throughput and AWAF license,  as throughput is a hardware parameter not an explanation of how F5 inspect http L7 traffic for AWAF.
    > I want to say throughput relies on i5600 hardware limits.
    > For more info about i5600 hardware Capabilites and throughput  , take a look in this Article:
    https://wtit.com/f5-products/f5-big-ip-i5600-i5800-hardware-datasheet/
    Also I would Like to inform you about expandtion from i5600 to i5800 , you can expand your license and take the advantages of i5800.
    Regards
  • Hi Ronenb,
    I have a different view here. While the throughput limits in the datasheet are theoretic numbers from a lab, the reality is often different. When the AWAF module on your BIG-IP is enabled the real troughput depends on different factors (for example which features of AWAF are used, how many attack signature patterns  are checked for each request). Roughly speaking: the more checks the AWAF performs on each request, the less troughput is possible.
    Since the sizing of a WAF requires quite a lot of consultation, I would recommend you to reach out to your local F5 representatives to help you with this project.
    KR
    Daniel
