17-Mar-2021 19:51
Greetings,
Do you know if the BIG-IP Edge clients will auto-update upon uploading and installing Edge ISO to the BIG-IP System ?
Thanks,
Edouard.
21-Mar-2021 08:12
In newer version it should auto update when connecting to the F5 APM that has a newer version but please check this article for permissions and if ''Component Update: Yes'' https://support.f5.com/csp/article/K31105289
