Nath's avatar
Nath
Aug 23, 2019
Solved
Best way to migrate Citirx ADC & Gateway to F5 Solutions
Hi Experts, I am gathering suggestions here on what is the best way to migrate Citrix solutions (ADC and Gateway) to F5 Solutions.
Please share your past experience on with this, any suggestions would help.
Thank you.
Nat
  • Build out the Citrix Gateway on F5 using f5.citrix_vdi.v2.4.5 iApp. The iApp is very simple. It will ask you for a DNS name for using this, so you should just use a test DNS name. Once iApp is configured, test DNS entry is in place, and firewall rules are configured, test it for a long time.
    After VERY thorough testing, reconfigure iApp to use production DNS name, and cutover your production DNS to point to the F5 gateway VIP instead of the existing Citrix gateway.
