Arnaud_Ciron_12's avatar
Arnaud_Ciron_12
Dec 18, 2007
Beginner : How to create an iRule to monitor SSL traffic ?
I'm new to iRule and BIGIP and we're using this box to terminate specific SSL connections (for credit cards equipments). Everything just works fine except I'd like to know :
1/ Why a connection was refused for some reasons.
2/ Who has terminated the SSL connection (which IP), because we're going to aggregtate thousands of connections and tcpdump is not appropriate.
3/ If possible : check the packet content after decryption.
I've search on the forum but still not found something useful so far.
Thanks in advance.
  • For a start, just a simple logging would be enough :
    How can I log successul SSL connections ?
    How can I log failed connections ?
    I've tried some code to log HTTP connection which is working fine :
    when CLIENT_ACCEPTED {
    log local0. "client: [IP::remote_addr]:[TCP::remote_port] -> dest: [IP::local_addr]:[TCP::local_port]"
    But I use HTTP only for testing purpose. When setup will be complete I will have to monitor SSL connections only.
    Second problem : As far as I known logging to local0.* is written in /etc/var/tmm. We'll have thousand of connections going to that bigip and I wouldn't like to have not enough disk space. Instead I use a remote syslog server with this part of code inside syslog-ng.conf :
    Send messages to localhost through udp port 514
    destination d_remoteLogTunnel {
    udp ("x.x.x.x" port (514));
    Performing logging
    log {
    source (local);
    filter (f_catchall);
    destination (d_remoteLogTunnel);
    How can I send connections logging only to remote server ?
  • hoolio's avatar
    hoolio
    In the syslog-ng.conf you can specify in your filter which events you want logged to which destination (local or remote) using 'match' and 'not match'.
    Take a look at this post from Tungstent as well as the overall thread for some additional info: (Click here).
    Aaron
  • Ok,
    I've managed to setup logging for successful connections.
    How about the failed connections ? As far as I known there is no event in iRules which could trigger an event when for example a SSL connection has failed ? (As a reminder I use a speciic TCP protocol, no HTTP here).
    Thanks in advance for your help
