jdewing
Cirrus
Jul 21, 2020AWS S3 Proxy
I’m looking for a best way to transfer files from on-premises to S3 VPC endpoint via F5 over AWS Direct Connect. The goal here is to route over the AWS Direct Connect, not via the internet.
On-premises --> F5 devices --> Direct Connect --> S3 Buckets
F5 devices is located on-premises not on AWS. I see that you may need to setup EC2 Proxy to work with S3 VPC endpoint. I tried that and have no luck.
Does anyone have a steps or suggestion?
