22-Nov-2022 03:54
Hello
does the AWAF subscription inclsude LTM as well , beaucse when i inatlled in the AWAF in the licensing pasge the LTM is unlicensed.
Please advise
subscription
Solved! Go to Solution.
22-Nov-2022 04:33
Hi @Ronenb ,
no need for LTM license provisioning.
LTM features are embedded in Advanced WAF license.
no need to configure LTM as a dedicated license.
Follow this Article , To make sure you are AWAF licensed on your system:
https://community.f5.com/t5/technical-articles/from-asm-to-advanced-waf-advancing-your-application-s...
Regards
22-Nov-2022 04:33
Hi @Ronenb ,
Regards
