pynot's avatar
pynot
Jul 03, 2017
AVR functions?
Just want to ask if AVR is only for HTTP traffic analysis?
Can this be also use for other type of TCP traffic?
Thanks,
Tony
  • eben's avatar
    eben
    Yes it can be used for TCP traffic. Create the profile and add to the VS. you will not be able to get analytics data at layer7 though.
    HTH. eben
