29-Apr-2014 14:25
Hello All, I am trying to set up following auto backup solution found here - https://devcentral.f5.com/wiki/iApp.Complete-F5-Automated-Backup-Solution.ashxDescription_1?NS=iApp
I have followed everything created the key as documented and I have tested from F5 CLI and I was able to SFTP and SCP without password (I selected the option backup on this f5).
However when I use the GUI and select the option SFTP or SCP it requires me to put in "Enter the SSH private key to be used for passwordless authentication" and "Set the remote directory the archive should be copied to"
So the question is for SSH private key do I get that from /root/.ssh/id_rsa ? and do I copy paste the entire key? Also for destination does it use "/" or "\".
Lastly where is log kept of this iAPP? I have looked almost everything couldnt find it?
Please help.
30-Apr-2014 13:19
01-May-2014 23:30
The key you are looking for should be /config/ssh/ssh_host_dsa_key
06-May-2014 19:15
06-May-2014 19:21
06-May-2014 21:30
07-May-2014 04:42
20-Nov-2014 06:41
I used ssh-keygen -t rsa to generate a new keypair and it is saved in /root/.ssh/id_rsa. You need to import id_rsa.pub in authorized_keys file of the receiving sftp server host in $HOME/.ssh. Make sure that you have the appropiate read rights on the receiving server to this file.
20-Nov-2014
06:45
- last edited on
05-Jun-2023
13:41
by
JimmyPackets
Also I used the following scripts to automate backup using SFTP and the sent an email if the upload failes. The local created backup files are automatically on the Big IP to save disk space.
!/bin/bashDATE=
date "+%m_%d_%y"
Here we create the ucs archive and append the date
tmsh save sys ucs bigip.backup.$DATE
upload SFTP to SFTP_servercd /var/local/ucs/ sftp backupuser@SFTP_server <
check if the upload has succeeded or failed. If failed mail error messageif [ $? -eq 0 ] then sleep 5 rm /var/local/ucs/bigip.backup.$DATE.ucs else ftp session failed mail -s "ftp backup file failed from BigIP" mail@mail.com < /dev/null fi
20-Nov-2014
06:54
- last edited on
05-Jun-2023
13:41
by
JimmyPackets
description !/bin/bash DATE=
date "+%m_%d_%y"
description Here we create the ucs archive tmsh save sys ucs bigip.backup.$DATE
description upload SFTP to SFTP_server cd /var/local/ucs/ sftp backupuser@SFTP_server <
description check if the upload has succeeded or failed. If failed mail error message
mail -s "ftp backup file failed from bigip" mail@mail.com
< /dev/null
fi
20-Nov-2014
09:31
- last edited on
02-Jun-2023
11:29
by
JimmyPackets
Hi! I just want to share a simple backup solution. Try doing this (source: ">http://www.linuxproblem.org/art_9.html" target="_blank">">http://www.linuxproblem.org/art_9.html😞
ssh-keygen -t rsa
Then you can give my script a try: ">https://github.com/rileyschuit/bash-tools/blob/master/bigip_backups.sh" target="_blank">">https://github.com/rileyschuit/bash-tools/blob/master/bigip_backups.sh
Adjust the array to point to your management addresses they use the argument "setup" to copy the public keys in the right place. Adjust the target directory as well, if needed.
20-Nov-2014 09:32
14-Dec-2020 08:34
Check out GitHub for the latest version of the F5 Automated Backup iApp, and submit any bugs or questions as an "Issue" on GitHub:
https://github.com/tabernarious/f5-automated-backup-iapp
