21-Mar-2022 03:28
Hello Members,
I am using a F5 BIG IP LTM version 15.1.2.1 in our Infra.
Can someone explain whats "GUI" option in Audit Logging configuration ?
The other options i am quite aware are the MCP and tmsh, which are already enabled and in use.
Curious to understand what audit logs we get if we enable GUI logging ?
24-Mar-2022 06:02
Hello Nikhilmbass.
That is the definition:
Specifies the log level for Master Control Program (MCP) events. The default is Enable.
Specifies the log level for tmsh utility events. The default is Enable.
Specifies the log level for GUI events. The default is Disable.
So, GUI is for web access and tmsh for CLI. MCP is the daemon that manages the configuration changes.
