Technical Forum
Custom Alert Banner
ASM working with xml compressed payloads
AlexS_yb
Cirrocumulus
Cirrocumulus
Hi
I have turned on ASM for one of our websites.  It seems to be throwing illegal request for payloads that are
content-type  - text/xml
content-encoding - gzip
which have null chars. The ASM say we are breaking XML.
But it looks to me like its not decompressing the data first before analysing as XML
1 ACCEPTED SOLUTION
Hello Alex.
I recommend you to check this out
https://support.f5.com/csp/article/K65342257
Regards,
Dario.
1 REPLY 1
Hello Alex.
Regards,
Dario.
